Hallo,
since update to 5.27 I observe that my Venu 2 doesn't measure correct altitude. There are differences up to 100 meter to the correct one. Is it possible to calibrate the measurement?
Hallo,
Thank you for your advice. I tried to calibrate the sensor first by using GPS according to the manual of the venu 2. After that the watch showed an acceptable altitude of my starting point. If will try this at my next workout. Perhaps that will solve my problem. If not I will try your advice.
