Bluetooth playback: stutter every 12-14 seconds
Just got the Venu 2 and tried pairing my Sony WH-1000XM3 as well as the Sony WF-1000XM4 headphones via Bluetooth and playing some music from Spotify.
Unfortunately, there's a brief stutter every 12-14 seconds. Enough to not want to listen to music via the watch, anyway.
Is my unit faulty or should I hold out for an update?
  • Ive got the same headphones - Just the version before hand (WF-1000XM3), and ive got the same issues with my Garmin Venu 2 and the headphones.
    Playing music is fine untill i set the watch in training mode (Running, Strength training etc), then the sounds starts to stutter quite bad.
    Whats your status Here? Found a solution, or given up?
  • Also should mention that the everything was working properly about 2-3 weeks ago
    I'm having the exact same issue with the headphones, but only when using strength mode.
    It goes back to normal eventually after a few minutes, but it sucks when my music is stuttering when doing a set.
  • Hmm.. I recently sent mine back to the store i bought it from. They are having a service on it now, so I will respond about their findings when I get it back ! :)
