Garmin Venu 2 Plus + Rogue Echo Connected Console
Hi All!
I have a Garmin Venu 2 Plus and I would like for it wo pick up my Rogue Echo bikes metrics?
The console/pc on the bike DOES have Bluetooth and Ant+ and I have managed to connect it to my phone using another app and it DOES show the data in real time. (here is the link to the console/pc - LINK)
When I search for the Console/PC on my watch nothing shows up?
  • I have the same issue:/
    I ask to the rogue support  an help, I will update this post when I will have an answer
  • Hi,
    You can enable only the heart monitor from the Venu 2 Plus, but it cannot pair with the Rogue to display workout data. Here is the official response from Rogue support:
    “The Echo Bike console uses the widely adopted industry standard FTMS protocol.
    Unfortunately, Garmin does not support this, and we are sorry for any confusion.”
    To display the heart rate from the Venu 2 Plus, you need to enable heart rate transmission by going to SettingsCardioTransmit During ActivityEnable.
    Then, start the activity on your watch, and press and hold the connect button on the Rogue bike for two seconds. After a moment, it should display your heart rate monitor.
  • For pickup the data on the Garmin console you can buy the "Garmin speed & cadence sensor 2" and set the wheel at 1410mm.
    For the power data Garmin have the pedals rally sensor but are very expansive comparing to the rogue bike and I'm not sure that you can mount it
