I connect my venu 2 plus through garmin connect and it all works fine for a few hours or so.
Once it loses connection becuaee it's out of range it barely works again and I have to reconnected the phone by going back into garmin connect and then re-entering a 6 digit code. Surely the watch, once paired, should remain paired?
Occasionally when I go into garmin connect to do the above process the watch has disappeared and I have to go through the whole set up process again. It is very annoying.
Any suggestions on ways to fix this?
