How to adjust the weather on Index S2?
Comment ajuster la météo sur Index S2?
Merci!
Merci!
In the Index S2 config, there is nothing to configure. Elsewhere I let Garmin have access to the phone's GPS at all times. When it is -10c here he tells me that it is +25 and forecasts 30c ...
It is in User Settings. It does not matter whether there is something to configure for the scale or not. The setting is there anyway.
In the general setup, at the Weather Position, I changed it always.
Before it was when the application is open only that it can fetch the GPS position of the phone but it also does not work with always.
When I open Garmin Connect, Bluetooth and GPS automatically open.
It only remains for me to put a fixed position to test ...
In addition I believe that this configuration place is for the watch widget and not that of the Index S2 scale ... Even changing for fixed position there is a difference of 40 celcius enter here and the data of the scale ... I do not know what to test other ...
Ok, my problem is that I want the weight in lbs but the temperature in celcius. Can Garmin correct the app to be able to make this adjustment? In Canada, most of them work ... Thank you!
I've been waiting for this for a long time. Weight in pounds, temperature in celsius.
+1 to this. On Garmin I have mixed units configured - weight in lb but the temperature in °C.
My Fenix watch shows the weather forecast correctly in °C.
However the scale still shows the temperature in °F.
The weather data is based on the IP address of your home network, not the location settings in the phone/app
https://support.garmin.com/en-US/?productID=679362&faq=nR1gc72ohvAukzZF58HN06&tab=topics
