Since garmin seems to be in denial and not providing a solution, I've noticed if I add 5" to my height in the device user settings, my BF% is closer to what is accurate. My activity level is set to 10 as well.
Ah yes... I'm not over-weight, I'm under-tall! My scale told me so! ;)
You're correct! My Inbody shows me at 12% BF, but the S2 says I'm 22%. I added 6" and now the S2 reads 11%. Thanks for the advice, Garmin can you please fix the algorithm?
They've abandoned this product. There hasn't been any software update for it in over 7 months. What should be a 5 minute job to fix, is for some reason…
I did the same (added 15cm height) and the scale dropped from 19% to 10% which close to reality. I am approx 11% so I will tweak the height slight lower. This is not a good solution though.
be careful, next your vo2max goes crazy!
I suppose I should expect something else could "break" :-D I have many garmin devices which could be affected...... lets see...
I agree, it's a horrible solution, but haven't found a better one.
If you know it's off by 8%, just subtract 8% (in your head) whenever you do a weigh-in.
Also not a great solution... but better than screwing around with a setting that will likely impact all of your other metrics.
They've abandoned this product. There hasn't been any software update for it in over 7 months. What should be a 5 minute job to fix, is for some reason just not happening, and at this point I don't think it ever is. Kind of silly they're willing to throw this whole product line away just because of a typo in their bodyfat algorithm they don't want to find and fix.
