That's how it's meant to work, it only brightens and flashes if the car behind is gaining on you. From the overview on the web page:
•Tail light unit brightens and flashes to notify approaching traffic of a cyclist ahead (underlining is mine)
Just a thought for those of you worried about the dot dissappearing, how does the Varia behave if you're cycling in a group, you could have a dot on the screen for the whole of the ride. :confused:
I don't have an issue with a car behind me. My issue is that the Varia display shows cars approaching but then stops displaying them when they are travelling behind. What I am saying is the dot should continue to be displayed when a car is following and drop off when the car passes. If you don't agree please explain why it's right to stop displaying the dot.
Richard
I agree that the Varia's doing what it's meant to be doing, but I also agree that still showing a vehicle once it's matching speed behind you would be a very useful feature if it could be made available. I don't think anyone's suggesting that the Varia doesn't replace the need for a visible check behind, but it can complement that and by doing so increase safety. Personally, I do most of my riding down country roads, and every so often I'll get a car behind me that just doesn't seem to want to overtake, even when there's a sufficient straight, which can be a bit unnerving as I find myself thinking "is it still there, has it turned off" etc. I end up regularly glancing round which isn't always ideal on pot-holed country lanes - having the white dot stay on my Edge would be great for me under those circumstances.
I've not had chance to try yet, but I would have also thought there would be a danger of a vehicle pulling out of a junction behind you not registering if it matched speed with you as it came out of the junction, or even round a bend.
YMMV
In the same way it filters vehicles travelling at the same speed as you? ;)
Don't get me wrong, I'm in complete agreement with you. While I like what it does, I would love it to show a vehicle matching its speed behind me. That would make it more complete. I absolutely agree there, it's just that that it would require a lot more complex tech. Think of the Varia as something similar to a police officer's radar gun, rather than the radar that an air traffic controller uses. The radar gun only give readings when an object is moving away or towards it. It will not tell the officer specifically which vehicle it is, but by pointing specifically at a certain vehicle, the officer can be pretty sure which one it is. However, if the officer were to try to use the radar gun from his moving police car at a car in front of him moving at the same speed, guess what speed it will show? Zero. What if the car was going 5 mph faster? 5 mph. The car mounted radar guns have info on how fast the patrol car is going so that it can calculate and give a speed for the car being tracked. I have a feeling that the Varia has some sort of threshold such as 5 mph which was discussed earlier before reporting a dot to help filter out false alarms. So, maybe if the Varia had two way communication with the Edge computer and knew when say, it said you were going at least 5 mph, they could get rid of the 5 mph threshold on the Varia and let it report anything that was behind you, even a "static" object. Then it might be able successfully show a car that has slowed down and started pacing you. The knowing that you are moving would be critical I would think to keep if from reporting every single object behind you, moving or not. That way static objects would be moving away from you as you pedaled and would be treated like cars moving past you. I don't know if the Varia is transmit only or can receive data. If it can, the solution could be a firmware fix away. Otherwise, we may have to wait for the next evolution.
