Even though i have the settings for My Speed and Vehicle speed swithched on overlay on video it is not showing up on video any ideas ?
Same. Mine use to as well. I was loaned a Varia Vue from my LBS to test. When I went to setup the Varia Vue I saw there was an update for my 715 so I did it. Ever since the update I no longer have this data. Also updated my 1050. Not sure which update broke this metric but hopefully a dev sees this and can fix it in a new update next time.
The Varia app says you need a compatible Garmin device or phone. Are you riding with one of those and have them connected to the RCT715? I guess you have to share your location too with the app if you are using your phone.
They don't have a built in GPS
You talking about the Varia app gave me an idea.....I always use my Edge 1050 but decide to actually open the Varia app. The app has some more settings in there that don't show on the Edge 1050. GPS and Speed overlay were set to off. I turned them back on. They must of defaulted to off when I did the update.
Should all work again on my next ride with my Edge 1050.
Hmm.. if the arrow indicating that location is being shared is showing up (as seen next to the time image below) when you are using the Varia app, and you are still not seeing location then probably just have to try the basics like properly closing the app, or restarting the phone..
