Garmin Varia UT800 & RTL515 problem with Garmin Edge 540
Hi!
During today's ride I suddenly encountered a problem with my Garmin lights - they stopped working.
For over 6 months I'm using RTL515 and everything was fine - it worked perfectly.
3 weeks ago I bought UT800 to finally be aware of battery level and have centralized control of both of my lights. But recently I made my Garmin Edge 540 firmware update and also I deleted my lights and paired them again.
Due to weather here (Poland) today was a first ride since that and I noticed that they don't work with my Garmin Edge. After I started the activity timer - they remain silent (or should I say "dark").
After few tries of getting them to work (delete sensors, pair again) nothing changed, so I deleted them and just turned them on without garmin edge control.
After ride I made some tests. If I set lights mode to auto,and lights turning on when device is turned on - they work till I will start activity timer - then they remain dark. If I set lights mode to custom they work till they connects to bike computer, after connection - dark. After timer start - nothing changes.
If I try to set mode manualy from main garmin screen (scroll up for additional custom settings) they flash for single flash cycle and they again remain dark.
Same story with lights options - when I go to lights settings -> radar/lights -> lights mode. It shows "turned off" If I switch to any of modes e.g. day flash - it sets to day flash for single blink and then switch to turned off again.
Does anybody had same problem? Do you have any idea what is wrong? What could I set incorrectly?
Thank you for any advices!
    I encountered a similar issue when I upgrade my Garmin Edge 530. After the firmware upgrade, my Edge530 had issues staying connected to teh UT800, and I had near constant error messages regarding light network being formed, and then the light being disconnected. I had to manually connect to my RTL515, so I could get radar working. When I looked at my sensors, I noted that the UT800 showed a light with questions marks inside. I executed a hard reset on the UT800 by holding the power button for 8 seconds, then entering pairing mode. I did not delete the device from my Edge530. After these steps, I could see and control the UT800. I am not sure if the firmware upgrade to the Edge530 was the root cause, I am just assuming that is the issue, since it seemed to coincide with the start of the issues I experience.
