i got a replacement 1030. initially the varia worked on it but the light wasnt so i decided to repair it fresh. I deleted it from the garmin, now when i try to re-pair it it no longer is coming up when i "search all" . any ideas???
Have you enabled pairing mode on your varia radar? www8.garmin.com/.../GUID-83345F4C-DAC5-437D-A10F-1EE92E92B980.html
hi i did this a few times....turned out i had to "reset" the radar by pressing down the power button for 8 seconds
As lights can be controlled only from one device you have to reset it to get it into paring mode.
