Hi,
I'm building a new bike that will have a Generator Hub.
I'm trying to figure out if I can wire an RTL-515 directly into the system so that it is kept charged.
In general you wire the Rear Light to the front light - and the front light delivers about .3 Watt to the rear at about 5V
As the Varia can be charged by an USB which seems to be in the same range - will this work?
When stopped there in general is a Capacitor in the front light to keep the light from going dark when stopped - I would guess this would keep the charging from cycling on and off - however you have the internal battery in the Varia to keep it from going out as well.
Will the Varia accept external charge while in use?
Thanks
