Help with pairing Varia RTL510 with Edge 1030
Hi, I've been having some trouble, and wanted to check if anyone had ideas or suggestions before I try the Garmin help support.  I recently got a new Garmin Edge 1030 and Varia RTL510.  I got the Edge set up fine, then after a little bit of effort, I thought I had the Varia paired.  But when I rode my bike, I didn't get any radar information from passing cars, the sensor display for "Radar" and "Light" were both dimmed.  I thought maybe I messed something up, so figured I'd delete the Varia and try re-pairing.  After I deleted the Varia from the Edge, I tried re-pairing, but it wouldn't take.  I tried both search for any sensor, and searching specifically for radar.  Nothing.  Then I thought maybe there was something in the Edge that remembered disconnecting from the Varia, so reset the Edge completely.  It still won't pair with the Varia.  The purple light is flashing, the two devices are sitting within a foot of each other.  The Edige just keeps saying "Searching" the Varia just keep flashing purple.
Any suggestions or thoughts of other things I should try?
Thanks.
