Varia Remote Stops functioning when using the Edge 1030 ver 9.10
Hello,
Has any one run into the issue that the Varia light remote stops working and you cannot control any of the lights. The remote will inital setup and I can control all the lights. I can get the left, right rear lights to blink on command to indicate a turn. I also can change the angle and intesity of the headlight. This is also working in conjuction with the edge 1030 and the RTL 500 light. Since the update of the 1030 to 9.10, after about a minute the remote stops working and when you push any of the buttons on the remote, the unit will just blink a quick green light while you depress the button and you have loss control of a very good saftey feature. To get back control you need shut off the the edge 1030 for about 5 to 15 mins and the varia remote will get out of this mode and reinitialize connections with the lights.
Edge 1030(ver: 9.10)
2 RTL300 (ver: 2.50)
1 RTL500 (ver: 3.80)
1 HL500 (ver: 2.50)
1 varia light remote
Has anyone run into this?
    Yesterday I happened to receive all of what you are asking. Due to the storm in UK I have yet to mount these and try them out. I also have the edge 1030 + edge 1000. I will try them out on both and let you know if I'm experiencing the same issues
