Will the VARIA's mount fit Argon 18 E117 seatpost?
Will the VARIA's mount fit Argon E117 seatpost? (which is flat, long  and rectangle)
  • It comes with and Aero seatpost adapter. Not sure if the shape. I’ll have to find mine and post a picture. There also may some making additive manufacturered ones.
  • The aero seatpost adapter fits nicely on my Specialized Shiv which appears to have a similar seatpost. You get two rubber washers that cover a suitable range of aero seatposts so my guess would be that you are fine. Might want to check out a local bike shop (and buy it from them) to be totally sure.
    0 Former Member in reply to biker128pedal
    Hi. Did you get it working on the Argon 18? I am trying to figure this out now. Thanks
    definitely not without some DIY and taping on top. the mount angle is too steep rendering the mount unstable. i have added some tape on top of the doubled whashers to cover the seatpost, but still the mount will unavoidably not stay perfectly centered. trying to find a 3d printing company but no luck so far. thought i had found the solution with Shapeways but the reviews are not really confidence inspiring...
