Where i can find this option "Auto-Beam Adjustment" on Edge 130 Device?
It is possible that GARMIN do again the half Job only?
thx
thx
I use a Garmin Edge 130 with a Varia HL500 headlight and with Garmin speed and cadence sensors. The HL500's beam adjusts brightness and range in accordance with the speed travelled. The faster you go, the brighter the illumination. This also works with my UT800 headlight on the Edge 130 (which I usually use with an Edge 830 on my other bike). The 830 has the option of turning the Auto-Beam Adjustment on or off. The 130 does not. It's 'on' by default.
