I forgot which update did this, but I had the same issue with the RTL500. For me this was great since my rides starts in the city I was get beeped every 10 seconds for the first 15 min. There has been a request that the alerts be channel through your phone to headset, so it can be used in the winter when you might have layers that would muffle the beep. I would like to get a quick Radar Tone button, so on the fly I can turn on and off the tone quickly,
My hearing is very poor and I can barely hear the alert tone even holding the 1030 next to my ear. I finally designed a bluetooth transmitter with a microphone that sits under the 1030 and relays the tone to a single earbud. It has worked very well but the earbud battery only lasts about 3 hours. I should not have had to go to the trouble of designing this work around.
I don't understand why Garmin can't modify the alert so it can be at least sent to a phone. Older riders like myself need the Varia and our reduced hearing should have been taken into consideration in the Varia's design.
same here. headphones are allowed here in holland and i always listen to music when mountainbiking. there should be an option to relay the sound via bluetooth to my headphones. I can hear the navigation directions this way so it should be fairly easy to mix the sound from the radar with the edge warnings and send them to the headphones.
