I forgot which update did this, but I had the same issue with the RTL500. For me this was great since my rides starts in the city I was get beeped every 10 seconds for the first 15 min. There has been a request that the alerts be channel through your phone to headset, so it can be used in the winter when you might have layers that would muffle the beep. I would like to get a quick Radar Tone button, so on the fly I can turn on and off the tone quickly,
My hearing is very poor and I can barely hear the alert tone even holding the 1030 next to my ear. I finally designed a bluetooth transmitter with a microphone that sits under the 1030 and relays the tone to a single earbud. It has worked very well but the earbud battery only lasts about 3 hours. I should not have had to go to the trouble of designing this work around.
I don't understand why Garmin can't modify the alert so it can be at least sent to a phone. Older riders like myself need the Varia and our reduced hearing should have been taken into consideration in the Varia's design.
Ditto ditto ditto to all the posts experiencing trouble hearing the tones. Come on Garmin, do something about a fix..............
same here. headphones are allowed here in holland and i always listen to music when mountainbiking. there should be an option to relay the sound via bluetooth to my headphones. I can hear the navigation directions this way so it should be fairly easy to mix the sound from the radar with the edge warnings and send them to the headphones.
