Using Varia with dual tail lights
I have the (fat) head light with a pair of tail lights. I did a short ride this evening with the lights - first time in a long time, as the days are getting shorter. Everything worked well enough, but when I got home and into the garage, I pressed the "turn signal" button for a right turn, and saw that I had mis-mounted the tail lights so that I was actually signaling for a left turn. I've tried to keep the two tail lights so that the left light is always on the left of the headlight and the right is on the right, but I messed up.
I guess next ride, I'll test the turn signals before I start and make sure I haven't crossed my hands again.
It seems clear that I should mark the lights as L and R. Does anyone have a suggestion as to how I can do this? Maybe I should use a sticker? Or could I use a marker - white or yellow on the black case?
    0 Former Member over 5 years ago
    Colin would it be possible for you to tell me how you mounted the two of these lights to the back of your seatpost. I'm struggling to find any mount that would allow me to have these both side by side
    Gordon
  • I mounted my two lights on the seat stays using the mounts provided with the light i.e. use rubber inserts to reduce diameter for seat stay rather than seat post and secure using the rubber bands.
