Hi all,
Has anyone had any issues the the headlight?
I have a the std garmin tail light and headlamp paired to my edge.
Yesterday while going to work the headlamp went from low power to zero power and off within about 10 mins.
I run the headlamp in low power mode but I am sure that can't be right. What do other users get. This means that from a full charge I have 4.5hrs use when in low power mode.
When I repowered the light after charging it up it turned on in overdrive mode.
What would be useful is a configurable fields on the edge to see what mode (low, med, high, overdrive, flash) the light is in rather then having to trek through menus to find this information out and change.
