Does varia vision work with Connct IQ Datafields/Widgets and apps?
Creating apps widgets and datafields using ConnectIq is great
Which of these can I display on the Varia Vision?
Regards
Jamie Lowrie
    So does it work? Anyone?
    Looking to buy the Vario but I'm using some of the Connect IQ fields a lot.
  • I don't see an option to pick Connect IQ fields in the Vision data field options. That doesn't mean in won't happen...we just have to hope that Garmin will implement this option. But the developers will also have to translate it over as well...coding for edge display doesn't make it compatible with the varia display.
    And there's no pop-up function on the Edge so that if the Varia received a target a compatible page would pop up?
  • And there's no pop-up function on the Edge so that if the Varia received a target a compatible page would pop up?
    Yes. Currently(firmware 9.0), there is no option to display Connect IQ fields for the Vision
