My Varia light network (which really consists of only a Varia Rearview Radar), regularly disconnects from my Edge 520, and then reconnects again after a few seconds, with the "Light Network Found" message. When it disconnects, all other sensors (including power meter, speed/cadence sensor and HRM) also disconnect. The display data fields for these other sensors on the Edge 520 show blank during the disconnect period. The other sensors also re-connect when the light network re-connects.
The disconnect/re-connect seems to happen every few minutes, and the disconnect lasts only for a few seconds before re-connecting.
Initially, I was unsure if this is a Varia issue or an Edge 520 issue. To test, I disabled both "Lights" and the radar sensor. With that, the problem went away - no more disconnects. Which leads to the conclusion that this is a Varia issue.
My setup and configuration:
- Edge 520 (fw ver 3.10)
- Varia Rearview Radar (fw ver 3.00)
- Vector power meter (fw ver 3.90)
- Bontrager speed/cadence sensor
- Garmin HRM
- iPhone 6 (Bluetooth)
Light/Radar Config:
- Light Mode - Auto
- Radar Light Mode - Overdrive
