I replaced both batteries at once. The difference between R pedal and L pedal is 72w/268w. I did a reset, cleaned the contacts, reconnected to the meter. I did a calibration and reset the angles. Nothing helps.
Any idea what can be done?
Have you tighten the ports to the correct 4-5 nm?
mayby you have overtighted the port and needs new one.
that was the problem I had.
It is possible that you are right.
I contacted the service center. They are supposed to send me a new door.
I hope it will help
Did it solve your problems?
I got a repair kit. I replaced the entire socket. Nothing changed. I reported it. I'm waiting to see what happens. The pedals are under warranty
