Incorrect Power values
Question about my new RallyK 100/200. I just got them, updated to the latest software, installed them today, and calibrated them using farming connect app (0.03) was my reading for connect app. Then I also calibrated using my 1030 Edge and got the same calibration reading of 0.03. However, during the ride it was displaying I was pushing 350+ watts where I was normally pushing 185+ watts with my vectors a couple days prior. My FTP is 234 bit after todays ride it was suggesting my new FTP increased to 403. Is there something I missed with calibrating these new pedals? Or is this an issue with the newest software update w the pedals? Thank you in advance.
  • With brand new pedals its best to do a couple sprints on them following the first install, then repeat the calibration for best accuracy. From what you've said, the torque reading you're seeing (0.03) is expected behavior.
    A couple of other things you could confirm would be that the pedals are installed to the correct torque, and your crank length is set correctly.
