Hi,
¿someone is using original shimano cleats and has creaks?
I do not use the original garmin because I am used to cleats with 0 degrees.
Thanks
Look at the other topic on this forum: Two pairs of Garmin Rally XC200 squeaking when pedaling
In general some users reports squeaking sounds or creaks when pedaling. So far the only solution from Garmin is to ... lube your pedals. It helps a little but when riding in dirty environment problem is back after 10-20 km.
