XC200 Sensor Errors ?
I just went for my first ride with the XC200s (firmware 2.30).  I had them connected via ANT+ to a Fenix 6X and a 1030+.
I'm not seeing dropouts in the graph, but I did see sensor errors when I checked the the device after the ride:
  • Right Sensor was reporting 0 - 0 errors
  • Left Sensor was reporting  800 - 0 errors
Is this normal? Is this affecting the data being recorded?
  • I suppose it is some kind of calibration error code (32+768). Do a manual zero offset calibration, probably it will gone  (if not, remove batteries, put them back and do a full calibration procedure again with steady spinnning)
  • A Poster in a different thread suggested.. "If you have both an Edge and a Fenix connected, then make sure you have all the sensor settings exactly the same on the two units. That includes settings for crank length, and auto zero. You should also set the Edge's sensor settings to include TE/PS ON, since that is what the Fenix expects it to be."
    That appears to have fixed the issue.
