I don't know how to control music widget with just buttons, the select button just lower the volume and thats all I can do right now. It looks like the widget is made for touch but this unit does not have touch screen.
While not referenced in the change log, this has been resolved with the 28.20 release. When viewing the music controls widget, you can use the top right/select button to enter the controls for this widget…
In software beta v28.18 there is visible square around currently selected element in music player and this issue seems to be fixed
You can use the up and down buttons to navigate through the different buttons. But the problem is you can´t see which control is actually selected so you have to DJ through alle the buttons till you find…
I called Garmin and raised a support ticket.
You can use the up and down buttons to navigate through the different buttons. But the problem is you can´t see which control is actually selected so you have to DJ through alle the buttons till you find the control you are looking for.
Hope Garmin will fix that soon, besides the timing gates the music player widget was one of the main reasons for me to get the edge MTB.
While not referenced in the change log, this has been resolved with the 28.20 release. When viewing the music controls widget, you can use the top right/select button to enter the controls for this widget. Then you can use the arrow buttons to choose which control option you'd like to interact with.
