Firmware version 31.33 for the Edge Explore 2 is now available. This update can be downloaded through Garmin Express or Garmin Connect Mobile when available.
Phased Rollout 20% - 7/29/2025
Change log for 31.33:
- Added Support for Bosch smart system eBikes.
- Updated radar data screen to support the selected Color Mode instead of always displaying in dark mode.
- Fixed crash during course navigation.
- Fixed crash while searching for recent finds.
- Fixed translation issue causing "Day" to be added to date strings.
- Fixed elevation profile manual scale adjustments.
- Fixed crash using RTS to edit data screens.
- Fixed CIQ data fields causing UI lag/freeze. CIQ data fields will now start when you enter the timer loop or when an activity is started.
- Fixed options menu while start/stop/pause overlay is present.
- Fixed map data field locked to track up orientation.
- Fixed speed value on speed graphical data field.
- Fixed contacts not displaying on remote widget for inReach mini 2.
- Fixed label alignment on the timer overlay.
- General improvements to device stability and addressed various minor bugs
