Problems updating explore 2
Made a protocol how to finaly upgrade my explore 2 which was still hooked on map software from 2021.22 and refused the updates
Update maps problem with the Garmin Edge Explore 2
The Edge Explore 2 only has 16GB of internal storage. The new 2025.10 map files are cumulatively so large that the device does not have enough temporary space to overwrite the old maps, causing Garmin Express to give an error message halfway through or even tell you that the update was successful, while when you check the maps on your device, you find that they were not updated.
It should also be mentioned that Garmin has changed the naming from 'Cycle Map' to 'TopoActive'. The old maps that are in your newly purchased EE2 date from 2021 and were named, for example, INTL Standard Base Map, Garmin CYCLE Map EU 2021-22 West, Garmin Cycle Map EU 2021-22 East.
Now first check which card files are on your EE2. To do this, go to menu - Activity profiles and then choose Cycling - Navigation - Map - Map information.
Now connect your EE2 to a USB port on your Windows PC. Your EE2 will be installed and now if you click on the symbol of your EE2, you can find it in the Folder This PC – Devices and Drives, and you will see the various folders and files that are on the device.
Look for the following files: gmaprom.img and also if there are several versions such as gmaprom1.img and 2, also all gmaprom.gma and those ending in .unl. Also search for D6285160A.img and D6185160A.gma. You should definitely delete these files, otherwise the update will fail again.
What you should definitely not delete is the gmapbmap.img folder and the D4728160A.img and D4713090A.img folders.
Download Garmin Express for Windows now and install and launch the program. However, first remove your EE2 from the PC. Turn off the EE2 and restart it, so that it cleans up some cache remnants. Now you hang it back on the PC and the device is recognized by the Garmin Express. A green light will turn on and there will also be a "Connected" message.
Now Garmin Express will also see that your device needs map updates. You search for the desired file name, for Europe this is the Topactive Europe 2025.10. Choose to update.
It takes a while now (but not hours as indicated). It will then be notified that the update is ready.
Now remove your EE2 from the PC again and boot the device to check if the maps have been updated. To do this, go to menu - Activity profiles and then choose Cycling - Navigation - Map - Map information. Here you will now find the new maps and they are the following:
  • TopoActive Europe West 2025.10
  • Standard Basemap
  • Garmin DEM Map EU 2023.10
Mission accomplished, but in the meantime the next update is already available, namely the Topactive Europe 2026.11. Pair your EE2 back to the PC and restart Garmin Express. This determines that there is an update and you just have to click on it. After finishing this installation, remove your EE2 from the PC again, start the device and check if the following cards are now on it:
  • INTL Standard Basemap, NR
  • Garmin DEM Map Europe 2026.10
  • Garmin Geocode Map Europe 2026.10
  • Topoactive Europe, West 2026.11
Good luck !!            Date : 25/06/2026
