Hi all,
I want to change navigation line from pink to other colour but i try edit classic color them and not helped, maybe it's now closed by Garmin?
For Gramin maybe you can add to menu tab for change color line?
Thanks
Hi all,
Thanks
The original .kmtf theme files are refreshed from backup at every restart. So trying to use a modified original classic.kmtf theme will never work. If you want to experiment with theme files you should copy the original to a new file and give it a new name. So, for example copy classic.kmtf to test.kmtf and experiment with the latter.
This was answered just 3 topics below yours, especially the first link in that response
And that previous post is now a few years old but since then there are probably 100+ additional topics posted and answered and may extensive discussions (hint search on "maptheme" and "MPM_ACTV_CRS_CLR" in any of the x40 forums especially 1040 the best.
These relate to the course line, the darker magenta, unfortunately the Turn Guidance pink line can't be changed
Read on....
