Popularity routing is unchecked in Course Creator routing preferences, despite being checked in the Activity Profile navigation routing settings. Furthermore, checking the setting in Course Creator doesn't seem to have any effect as entering the routing preferences again right after has it unchecked again, while all other changes to the routing preferences persist.
Steps to reproduce :
- Make sure the "Popularity Routing" setting is enabled in the current activity profile
Menu > Activity Profiles > [select profile] > Navigation > Routing > Popularity Routing --> ON
- Create new course from that profile and select any starting point
Courses > Button + > Course Creator > [select any start location] - Open Routing Preferences from the Map Overlay. Popularity routing is unchecked while all other preferences are the same as in the Profile settings.
Map overlays (top right corner button) > Routing Preferences - Cheking Popularity Routing and exiting the menu still results in the setting being unchecked when going back into the Routing Preferences straight afterwards, while any other change persists for the duration of the Course Creator session.
Device : Edge Explore 2
Firmware version : 25.25
