Temp is always higher than actual temp by about 4 degrees or so. Anyway to reset or calibrate?
Leave the meter turned off for 2 hours in a room with a room thermometer, placing them close to each other. Then, without holding the meter in your hand, turn it on and check the temperature on the meter compared to the room thermometer. Leave the meter in a visible place for an hour or two and compare the temperature readings of both thermometers again. Record the results of these measurements and present them here
