Edge explore 2 and home trainer
Hello everyone, has anyone managed to pair an Edge Explore 2 with a Tacx Flow Smart home trainer? Garmin states on their website that they are compatible, but the GPS does not detect the home trainer. Thank you.
  • I had similar issues connecting my Zwift Hub One, but eventually found a trick to connect it properly.
    I don't fully recall how/what I did but make sure that:
    - Your phone and/or laptop/PC it's Bluetooth is temporarily turned off (so the trainer isn't connected there yet)
    - Power off the smart trainer
    - Restart your Garmin Edge
    - Have it search for Smart Trainer sensor
    - Turn your Smart Trainer on again
    My Zwift Hub One would only connect at the very start when it turned on, if it didn't get a chance to first connect with an already paired phone/laptop/PC.
    Once connected to the explore 2 you can continue connecting it to other devices in parallel.
  • Thank you. Indeed, the fact that my phone was in bluetooth should have prevented the home trainer from connecting to the GPS.
  • This is strange. I have a Wahoo Kickr Core and it can connect to both the Explore 2 and a phone at the same time (Ant on the Kickr, Bluetooth on the phone).
