Hello all, after upgrading to 24.20 the map orientation is fixed to North-Up, changing to Track-Up can be configured but won't work.
I then downgraded to 24.05 and all was good again (though losing all the configuration)
WTF? Please, not another bug!
I don't want their "great" updates.
Garmin, please let us disable auto-updates; I am not your free beta tester, I just want to use my device to help me navigate in a foreign lands. :(
I have been two weeks without syncing my Explore 2 to Connect because I do not want the flawed update.
Not on my Explore 2 with firmware 24.20. So probably not a bug in 24.20 but rather a specific issue with your device. Not very popular, but you may consider a full reset of the device (remember you loose your settings and personal files, so backup first).
After having downgraded (which is identical to a factory reset) to 24.05 i gave it another try and once more upgraded to 24.20: all worked flawlessly again, map orientation was Track-Up.
So apparently there is no bug with map orientation in 24.20. But as i have never changed the map orientation from the beginning, obviously there is a problem with some settings (unknown to me)
