Sensors disconnect after wake up from sleep
Hi
Purchased my Edge Explore 2 recently and connected to my HRM, RTL515 radar light successfully. If I stop during the ride and after the unit wakes up after sleep, all sensor connections are lost and only way to reconnect is power off and on. Any suggestions how to reconnect the sensors without rebooting the device?
Top Replies
All Replies
  • Impossible. This problem lasts forever, Garmin does not care or just cannot fix this problem. I'm hoping they will just add option to disable sleep mode and leave only poweroff because its straight dangerous right now, you start your ride and you can easily miss that your radar and lights are off.
  • First 5 minutes not work hmr and speed/cadence
  • Thanks all for your participation in the Garmin forums.
    : an error preventing sensors from reconnecting automatically after resuming from sleep mode was identified and resolved in version 24.20 and the most current software versions for the Edge Explore 2.
    If any users continue to experience this error, or if you experience something similar with a different model Edge, please reach out to me here or contact Garmin Support for your region - https://support.garmin.com/
