change magenta line color
Best
I hope there is someone who can help me with something.
I have a Garmin Edge Explorer 2 and it uses a magenta line to navigate.
Now I'm getting a bit older and I notice that I can no longer distinguish this color from the blue color that is referred to as roads.
I have already tried everything in terms of settings in the standard themes that are on the computer.
I have read several forums and there are several people with this problem
It is possible to adjust the color of the line, but I am unable to do so.
See the forum below
forums.garmin.com/.../how-to-make-course-line-easier-to-see 1
Is there anyone who can change the color of the magenta line to a yellow color for me?
If you can and want to do it or have any questions, please send me a DM.
Top Replies
  • ClassicYell.zip
    See if this works for you. Unzip and copy the file into your Map themes folder and then select it in your activity profile.
    Menu>Settings>[your Activity Profile]>Navigation>Map>Map Theme…
  • ClassicYC.zip
    Here is a plain yellow cursor.
All Replies
  • It was quite some time ago but I think I used the Classic theme as a template, removed some code blocks and then added blocks from other themes. Colours were then tweaked to suit what I wanted.
    The custom theme only needs to include items that are to be changed and everything else should stay as the Garmin defaults.
