Cycling maps on EE2
I don't need the cycling maps from East and Central Europe.  How can I delete thos maps because they take a lot of place and it is not possible tot put a microSD card
  • You can try to delete the two 2024.10 mapfiles 'East' and 'Central', including the .gma companion of the East mapfile. No guarantee however that everything keeps working. If you are on a Mac don't forget to empty the trash!
    - D4728160A.img = Geocode Map 2024.10
    - D6016110A.img (+ .gma) = Garmin Cycle Map East 2024.10
    - D6017110A.img = Garmin Cycle Map West 2024.10
    - D9499040A.img = Garmin Cycle Map Central 2024.10
    You can make a backup before deleting the mapfiles from the device, but you also can reinstall the maps using Garmin Express.
    Be aware that Garmin Express will continue to signal that a map update is available after deleting a map subset.
