Ftp estimate and test ?
Need a new Unit, but i am unsure if i should Pick 540 or explore 2.
I would prefere explore 2, but there are two things i cant figure out.
1. Can i get an ftp estimate through the explore 2 ?. It is good enough if i Can just see it in garmin Connect. From the manual i Can see that it gives a vo2max estimate, but nothing about an ftp estimate, but since that is based on vo2max, Will it be avaliable in garmin Connect ?
2. Can i do a guided ftp test with the Explore 2 ?
