One of the screens you can use is the music control screen. It can play, skip tracks forward and backward from your connected smartphone.
I followed the user manual on this, but sadely it does not work. Does someone know the solution for this?
That screen works for me. Maybe try to control some other music app on your phone.
Hi, which music app do you use?
It works with native one that POCO phones come with
try this for both the connect app AND the music app you are using:
Access phone’s Settings.
Select Security.
Select Battery.
Select App Battery Saver.
Select the Garmin Connect app.
Select Background Settings.
Set to No Restriction.
Access phone's Settings.
Select Apps.
Select App Lock.
Select the gear icon (top-right).
Select Hide Notification Content.
Uncheck apps that aren't getting notifications on your Garmin device.
Access the phone's Settings.
Select Apps.
Select the Garmin Connect App.
Enable Autostart.
Adjusting these settings will ensure that the Garmin Connect app is fully running on your smartphone.
Hi, I tried this but the issue is still the same.
can you describe how it is not working? do you have a screenshot?
This is what I see. I don't see any track.
And if i press play, nothing happens.
