Twice since the last update my heart rate went blank after approximately 40 minutes of riding. Didn’t have that before the 19.21 firmware
Never had this issue after installing firmware 19.21 on 20-dec-2023 (10+ outdoor rides). My heartrate monitor strap is an ANT+/Bluetooth non-Garmin brand strap (XAND), connected via ANT+.
I have not had this problem for the last couple weeks, so hopefully it does not come back. When the HR does drop out the only way I have found to quickly reconnect again is as follows:
Pause Ride
Click…
Pause Ride
Click Power Button to go into standby mode
Click Power Button to come out of standby mode
HR monitor should reconnect in a few seconds
Un-pause ride and continue on your way.
Hi I have noticed that if i power on Explore 2 just before my workout starts and I have my heart rate monitor in place, it works fine. If the connection is done earlyer ( inside apartment) and i have Explore 2 switched on, it repeatedly, maybe every second time loose connection to heart rate monitor and 4iiii device. I can only have a connection back, if I power off and on explore 2. Somehow it looses "initial" settings which I assume, what it does during power on.
I have had this same problem, since an update, I bought the garmin a month ago, for two weeks, no problem.
After updating, the same thing, randomly, disconnection of all sensors (speed and cadence).
If you pause the route, turn off the screen, turn the screen back on and press play again, they will reconnect immediately.
Yesterday by chance, a route of more than three hours and not a single failure, it turns out that I left my phone at home (xiaomi), the same thing has to do with something with the phone's Bluetooth connection, I don't think it's a coincidence that it's just perfect the day I forgot my phone at home.
On the next route, I will try to disconnect the Bluetooth from the phone.
