Although it worked when I first got it I am now not able to see the cadence display from my Bontrager DuoTrap S on my Garmin Edge Explore 2 (Software Version 9.07).
I can't pair the devices using ANT+ only with BLE. And that doesn't work.
The DuoTrap S has a fresh battery. I don't have any other speed or cadence sensors enabled.
When I attempt to pair it from the menu Sensors > Add Sensor > Speed/Cadence.
The "...rotate the crankarms" messages appears; I do so and the red and green lights on the DuoTrap light up.
The screen "Sensors Found" appears but  none are shown, only "Show Bluetooth Sensors" appears.
When I select it "Speed/Cadence DuoTrap S" with a check box.  I click Add which does add it to the list.
When I start recording on the Garmin it shows Cadence as "--". When I turn the cranks or ride the bike it changes to "0" and never changes.
