Hello all
I hope you are well.
I have the Bontrager Ion 200 RT/Flare RT Light Set Paired with my Edge Explore 2.
When the Unit is put into Standby, either by pressing the Upper Left Button or after 5 Minutes of Inactivity, the Lights will not reconnect when the Unit is turned On again.
If I turn the Unit Off and On then the Lights reconnect fine.
My Edge Explore 2 is on FW 9.07.
Is this a known issue?
Thanks in advance
Kevin
