Hi, just bought edge explore 2 and the UK map looks great. When I zoom over to Bangkok Thailand the map is very low detail. I’m cycling in Asia in a week, how do I get a detailed map? Please help
Try here for maps https://extract.bbbike.org/
Use the Latin 1 versions and if you are unsure of the general process to get a map onto the Edge, take a look here https://www.dcrainmaker.com/2019/08/how-to-install-free-maps-on-your-garmin-edge.html
You can add / switch maps using the Garmin Express app on your computer. Plug in the device and click 'Manage Maps'
Depending on the size of the file for the map region you want to add you may need to remove an existing map to make room in the device memory for the new one.
