I'm trying to find out the battery capacity in mAh, so that I can work out how big a powerbank I'dneedon a long remote trip. Anyone know?
I believe the Edge Explore was 1100 mAh?
Thanks,
Rob
Thanks,
Rob
Thanks. I think the battery life is quite a bit greater than the Explore? So in the absence of any firm data, I'd go with perhaps 1500? But if more, it'd make quite a difference over several days. Very relevant as I'm just back from 3 months in northern Norway, Finland and Sweden, where we went many days without access to charging.
The battery life of the Explore 2 is significantly higher compared to the Explore (1), but that can also be due to (much) less hungry electronics and / or better internal power management.
But indeed, seeing your multi-day trips in the northern area I can understand you need confirmed data about the battery. Even more important because the lower mean temperatures cause less battery capacity - I think you know better than me...
While it's definitely true that Garmin should give this information, it's not always that simple (from your point of view):
- it can depend on the cable
- it can depend on the charger (USB "negotiates" charging speed based on the capabilities of the chardeg device and the charger (and maybe even a bad quality cable)
So while you might get some official answer and you can divide thhe powerbank's capacity by it it won't necessarily give you that many times of full charge.
