I paired my Edge Explore 2 with the latest Bontrager DuoTrap s over Bluetooth and it connects. But no cadence data presents. This sensor worked fine with my Edge 830.
michaelfaas do you have any other sensors that are paired to your Edge? If so, could you list the make and model of these and whether or not these are working with the Edge?
On your Edge, go to the menu > sensors and see if the sensor icon for the DuoTrap shows up as both a speed and a cadence sensor or if it is just showing one icon. The DuoTrap should show both icons but if it is only showing one of these, I'd recommend removing and then re-adding it.
The duotrap is the only bluetooth sensor, I sometimes use an ANT+ HRM or BT HRM, but the cadence started working on it's own. Thanks for the support.
Glad to hear it is working for you!
