I think a thread with minor gripes would be useful, to avoid bogging down the forum and a central place for the engineers to scan through.
My suggestion would be to display the battery percentage on shutdown, as my 840 did.
Definitely agree on showing the battery percentage on shutdown. Coming from a Wahoo Bolt 2, here is what I miss:
* Battery percentage on shutdown
* Proper eat / drink alerts. Not the ones on the 850 that…
dont turn ON edge after unplug from battery charger.
* Proper eat / drink alerts. Not the ones on the 850 that pop up for 1.5 seconds and you end up basically always missing. It needs to persist until dismissed (or at least have the option to).
* Automatically connecting to my Power2Max power meter. Not sure why I have to manually connect on the edge every time, where the Wahoo just did it automatically.
Thank for thread.
1. When press and hold -> redirected to complete setting as is used in edge 830
2. Refresh of sensor connectivity as edge 830 (sync button)
3. micro adjustment notification - dismiss after 3sec
4. Les navigation prompts - currently: 70m notification, 50m notification, 20m notification… one should be enough - or setting for navigation notification
5. TyreWiz losing fast air pressure alarm
I don't know if i'm doing something wrong, but my 850 will stay awake on the home page. For example if i've left it on to finish uploading the ride and forget to switch it off, it's still awake the next morning... Never had this with 840, 830 or 820.
Possibility to change the two datafields at Turn Guidance popup. Or even delete them alltogether.
