How to view shift and gear data from Di2
I got a new bike with 11s Di2.
I added a d-fly module and it connected fine with my 840, I can see the gear I’m in, I can use the Di2 buttons, I see the battery level… it all works during the ride.
After the ride, the Edge shows me how many shifts I’ve made. Good.
If I load the fit file to sram AXS portal, I can see the stats on which gears I used the most, the graph of the gear ratio, the power per gear distribution… everything.
But there’s no way to see any of this after the ride on Connect. No mention of any data from Di2 anywhere. But the data is there in the fit file, because the AXS portal does see it. I can’t even find a way to view again the after-ride stats that the Edge showed.
Am I wrong, or did garmin actually half-ass the Di2 integration, recording data and then not providing any way to view it?
thanks!
