Hello, I cannot change data fields in the Climb Pro screen. Even tried with the phone but not able to do it. Firmware version is 28.34. Someone with same problem/solution?
Many thanks
you mean here? (activity profile, datapages , "climbpro when it is active" and under it) it is working, ofc, you can change only the 2 datafields on the bottom. i tried to change it via tappin on the device, but if you need, i can try the GC mobile config way also.
if nothing helps, try to make/duplicate a new activity profile, and try to customize in that, probably the used activity profile got corrupted.
