My Edge 840 will start a ride literally sitting on the desk... can we not get a feature upgrade that only auto stop/starts after it manually initiating the ride?!
This seems like a day one feature request.. just me?
Yep. GPS drift/imprecision can make the device think it's moving. For me, the best option has been to use a wheel speed sensor (Garmin, Magene, etc.) and set a manual threshold of 6kph. To start a…
It's not a new feature. It was on the Edge 530.
Note you're device will often think it's moving if it has a poor satellite connection. This is especially likely on your desk, unless your desk…
That's GPS related. Happens when GPS lock signal is not OK and the unit assumes there is move going on.
Had that a lot in 830, not so much on 840. 840 has better GPS options, so get those enabled for…
Note you're device will often think it's moving if it has a poor satellite connection. This is especially likely on your desk, unless your desk is outside! The recommendation is not to turn it on until you are outside.
If you want auto stop/start after manual initiation, then you can enable auto-pause, which is two pages up in the same manual.
Had that a lot in 830, not so much on 840. 840 has better GPS options, so get those enabled for better reception
you can also tweak the auto-start/pause speed. i have 6km/h set and seem to work OK, though GPS reception is key
Yep. GPS drift/imprecision can make the device think it's moving. For me, the best option has been to use a wheel speed sensor (Garmin, Magene, etc.) and set a manual threshold of 6kph. To start a ride, I set it to prompt me rather than start automatically. That way, it always starts exactly when and where I want it to.
