Version 27.13 - Speed Sensors dropping out constantly
Speed Sensors not longer stay connected even after re-paring directly after installing 27.13
  • I have the same problem, although I'm not sure but it's either more common or only doing it after entering sleep mode after a break during the ride.
  • I'm also having this problem after upgrading to 27.13 but not with speed sensor but rather with my Di2 (and therefore I posted separately here on forums). The Edge 840 is slow to detect the Di2 at the start of the ride, will lose it almost immediately once found, but if I resync the sensor a bit into the  then it will find the Di2 and then keep it. I tested the Di2 with my old 510 and it finds the Di2 in seconds.
    I hope someone from Garmin is reading these forums and will start looking into the sensor detection code in 27.13.
