On 27.13, if I'm following a course, especially long one, of ~30Km, if I detour and recalculation starts (as I want it to be) it will not finish and hold on 80% until I return to the original course, and then gets the "course found" notice.
I can load even more than 400 km long course with no problem, but when I detour, it has big problems to recalculate, and this is down until cca 100 km long courses. Courses shorter than 100 km usually…
I'm the only one having this?
I'm not having this problem with my 840
You might try to disable 'Popularity Routing'. Even Garmin admits that this option gives problems at this moment.
I can load even more than 400 km long course with no problem, but when I detour, it has big problems to recalculate, and this is down until cca 100 km long courses. Courses shorter than 100 km usually work well. Because of that I have to split long bikepacking courses to smaller bits to make it usable while detouring, etc.
Re @aweatherall question, If CycleMaps 2024 & Europe then the upgrade to TopoActive 2025.10 is worth a try, the change log includes
Fixes a known bug causing routing and course creation errors in Europe
https://support.garmin.com/en-AU/?faq=LR6HR5Xul6A9zoxySC5KM9
